delete meter
delete meter meter-name
Description
Deletes a meter.
Syntax Description
meter-name Specifies the meter name.
Default
N/A.
Usage Guidelines
None.
The following command deletes the meter maximum_bandwidth:
delete meter maximum_bandwidth
This command was available in ExtremeXOS 11.1.
Platform Availability
